configure ospf ase-summary delete
configure ospf ase-summary delete [ip-address ip-mask | ipNetmask]
Description
Deletes an aggregated OSPF external route.
Syntax Description
ip-address Specifies an IP address.
ip-mask Specifies a subnet mask.
ipNetmask Specifies IP address / Netmask.
Default
N/A.
Usage Guidelines
This command is only valid on an ASBR.
The following command deletes the aggregated AS-external route:
configure ospf ase-summary delete 175.1.0.0/16
Platform Availability
This command is available on platforms with Base license, or higher, as described in the Switch Engine v33.1.1 Licensing Guide document.
